bevvobevvy
Jun 05, 2022Guide
RBS750 Boot Loop - flashes white
Hey Community. I have a startup issue with my RBS750. 😢 Since the global push out of FW ver4.6.8.2 a few weeks back my RBS is stuck in a power-up boot loop. I cannot factory reset it. T...
Jun 06, 2022Guru - Experienced User
I recommend you reach out to the NG support team and see if they can help you with this. An RMA maybe needed.
bevvobevvy
Jun 06, 2022Guide
... thanks so much FURRYe38 👨💻
I've emailed and called. Will try a few more avenues.
- bevvobevvy
