Therapydoc
Sep 19, 2023Aspirant
Rbs750 Ethernet setup
I have an Rbr750 set up as my main router inside the house as well as one RBS 7:50 in the basement and as far as the house I get pretty good coverage. What I’m looking to expand is the outside pool ar...
CrimpOn
Sep 20, 2023Guru - Experienced User
TP-Link TL-WA1201 sells for $40 on Amazon. It has only one gigabit Ethernet port for user devices. If you need more 'wired' devices in the shop that implies adding an inexpensive switch or moving up to a product with more ports, such as the Archer AX55. ($108)
Therapydoc
Sep 20, 2023Aspirant
This may be a dumb question but I’m not an IT guy. For this access point will I have to connect to a different Internet source on my phone or will it automatically continue with my Orbi from in the house?
- FURRYe38Sep 20, 2023Guru - Experienced User
If your phone is in range of the Orbi signal, of course it will connect and use the Orbi signal.
