PTWA
Aug 16, 2020Star
RBS850 - How to prevent 'wired' backhaul via Sonos
My Orbi RBR850 and two RBS850 with Sonos Boost connected to RBR850 runs perfect. To increase SonosNet coverage outdoor I connected a second Boost to RBS850. This temporarily did run perfect, boosting ...
Chuck_M
Aug 16, 2020Mentor
I had this exact issue about a year ago with an additional boost I put on the network.
My speeds for that network segment dropped to under 10Meg (which is the limit of the boost).
How many boosts do you have? How many speakers? How far apart are the speakers and boosts?
Just to validate: Are your Sonos speakers on SonosNet or Wifi? (I recommend moving them to their own network)
PTWA
Aug 16, 2020Star
Alle speakers are on SonosNet, currently 2xBoost in network, one wired to RBR850. Amount of speakers more than 10, physical distance of some is close. SonosNet shows a few yellow spots in the matrix, with additional Boost connected to RBS850 it shows alle green. Would be perfect if this RBS850 does not switch to wired backhaul.
