RVORBI
Sep 14, 2022Tutor
RBS850 wired backhaul poor connectivity
Hi, I have an ORBI RBR850(router) and two ORBI RBS850(satellites). However, I am having huge problems with internet stability. I will try to describe it in as much detail as possible. I have a fi...
- Sep 14, 2022- what other wired devices do you have connected to the router or the satellites?
- Please test to make router forget any wireless pairing with satellite 1. Disconnect the cable and in the web GUI (orbilogin.com) under “attached devices “ when you see the satellite marked as offline and you see a “Disconnect” button beside, click the Disconnect button to forget the pairing. Then do a factory reset for the satellite. Now never press the sync button without the cable being connected between router and satellite 1. Now connect the cable and press the sync buttons on both the router and the satellite. This way you have the router only paired on the wired backhaul. I had similar issues some time ago and that was the only work around to fix it.
Please also make sure that you have the latest firmware 4.6.9.11
