donawalt
Mar 08, 2022Mentor - Experienced User
Since firmware update - new network map?
See attached picture - I have two wired RBS850s and an RBR850 router. Since the update to 4.6.7.13 yesterday, it shows the 3rd floor router into the satellite into the router. Before, it showed both ...
- Mar 08, 2022
I power cycled the satellite on the first floor, left it off for a c ouple of minutes - that fixed it. I was guessing the 3rd floor satellite would then connect direct to the router while the other satellite was powered down, which it did according to the map. I still wonder why, when both satellites are direct connected, it showed one satellite connected to the other instead of to the router?
donawalt
- plemansMar 08, 2022Guru - Experienced User
when it happened, did you ever check it through the browser or was t hat through the map?
It wouldn't be the first time the app didn't display something appropriately. But the photo does show the hardwire connection.
Either way since its resolved, you can mark it solved so others aren't still trying to fix it :)
- donawaltMar 08, 2022Mentor - Experienced User
It was through the App. I forgot to check the web browser, sorry.
I'll mark it resolved. Here is a screen cap of the final:
- FURRYe38Mar 08, 2022Guru - Experienced User
Enjoy. 📡
So a screen capture of what it looks like after the power cycle would be nice.
