Deepak_Mehta
Mar 03, 2021Aspirant
Speed Issue
Hi All, I have internet connection of 300 MBPS upload and download both for RBR850 , but still speed is not increasing more than 100MBPS Is there any other settings to be done on the router. ...
Mar 04, 2021Guru - Experienced User
And with the RBR in place with your ISP ONT and a wired PC connected to the back of the RBR, your not seeing anything over 100mpbs?
Please post a screen capture of the Show Stastics page when you select this button under Advanced Tab/Internet Port section...
Deepak_Mehta
Mar 05, 2021Aspirant
Is there any other setting in RBR which i have missed to do?
- FURRYe38Mar 05, 2021Guru - Experienced User
And if you connect your wired PC directly to the ONT, what are you speed resules there. Please attach a screen shot of that test....
