tequillakilla
Dec 23, 2021Aspirant
Still connection loses and buffer overflows
In the meantime I've almost got used to the fact that the WiFi disappears for a few minutes every evening, only to return after what feels like an eternity. The fact that I reset the devices to the ...
- Jan 03, 2022
Thanks for the info. This Sagecom is a gateway modem. Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would recommend configuring option #2 for the RBR to ensure it has a good connection to the internet thru this modem.
Hopefully the suggestions witll help as well.
Enjoy. 📡
Dec 28, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
tequillakilla
Dec 29, 2021Aspirant
I've answered all of these questions so many times that I won't do it again now. Of course, I always make sure to have the latest firmware on all my devices and my satellites are connected to the router via cable.
My internet provider doesn't play a role here, as I said I have already used several manufacturers and the effect that the internet is not available for a few minutes every day only occurs now with Netgear.
After everything I have experienced so far, I am very sure that there is a buffer overflow somewhere and that it should finally be eliminated.
| Hardwareversion | RBR850 |
| Firmwareversion | V4.6.3.16_2.0.51 |
| GUI Sprachversion: | V3.0.1.2_2.1.30.3 |
| Operation Mode | Router |
As you see I have followed your advice and also changed to channel 48 for 5GHz. 2.4 I still use auto.
Best,
Klaus
- tequillakillaDec 29, 2021Aspirant
The jpg has not been send, let's try this way:
Auswahl der Region
Region:
Europa
Einstellungen für WLAN-Router (2.4GHz b/g/n/ax)
20/40 MHz-Koexistenz aktivieren
Nein
Enable WMM (Wi-Fi multimedia) settings (2.4GHz b/g/n/ax)
Ja
CTS/RTS-Grenzwert (Bereich 1 bis 2347):
2347
Präambelmodus
Automatisch
Transmit Power Control
100%
Einstellungen für WLAN-Router (5GHz 802.11a/n/ac/ax)
Enable WMM (Wi-Fi multimedia) settings (5GHz a/n/ac/ax)
Ja
2347
Präambelmodus
Automatisch
100%
- FURRYe38Dec 29, 2021Guru - Experienced User
Yes, ISP modems can be a factor in seeing some problems. Why we ask this question to better get a idea of what is at the head of the RBR. Please let us know what brand and model the ISP modem is.
Others have reporting having many odd issues with the current released version of FW. You can try this and see if this helps any:
It's only for the RBR. I have it loaded on mine currently and not seeing any problems since I loaded in 10 days ago.
Someone posted this as well for both RBR and RBS. I have not had a chance to load and try it out yet:
- tequillakillaJan 03, 2022Aspirant
Since there is unfortunately no fiber optic cable in my street, I use a gigabit connection via my cable provider. He made the SAGEMCOM F @ ST3890 V3 BBN available to me. I deactivated the built-in WLAN and only use this device as a converter from antenna cable to Ethernet, as well as for landline telephones. The reliability of the cable provider is very high and I have a problem with it once every three to six months on average. As a rule, this is easy to find out because the WiFi signal is strong but no internet works. A restart of the SAGEMCOM is then sufficient to fix the problem.
With regard to my ORBI RBR850 problem, the system has actually been running without a single dropout since I made the suggested adjustments. Thank you for the valuable information!
I am now curious whether something will change in this situation after 6-8 weeks, that was always the critical mark for a reset to the factory settings.
