kemalizing
Sep 25, 2024Follower
Re: Streaming issues with RBR350 (constant buffering and pixelation) when using Chromecast
I have the same issue on my RBR350 but not only on chromecast. I have a TV which has a built-in chromecast and has this issue but I also have a macbook, which has the same issue! both of them are con...
Sep 25, 2024Guru - Experienced User
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is any of the following enabled?
Armor, Smart Parental Controls, or Traffic Meter.
FW on devices up to date from the Mfr?
