jdkorbi
Oct 17, 2023Aspirant
Torguard VPN with Netgear Orbi 753
Has anyone had success in utilizing a Torguard VPN on the RBK753 router with Firmware Version V4.6.14.3_2.3.12. Torguard support can provide assistance if the router utilizes dd-wrt, openwrt, or...
- Oct 17, 2023
If you can find support for that, I would suppose.
Only VPN info out there for Orbi:
https://kb.netgear.com/31489/How-do-I-use-VPN-on-my-Orbi-system-with-my-iOS-device
Oct 17, 2023Guru - Experienced User
All 3rd party VPN software is not supported on stock NG FW.
jdkorbi
Is the only solution to use/flash the router to use third-party firmware?
Does Netgear offer a VPN solution to simply safeguard geolocational information?
- FURRYe38Oct 17, 2023Guru - Experienced User
