SKEN57
Dec 27, 2021Aspirant
Unable to cast via RBS750
I have recently switched over to an RBR750/RBS750 wifi 6 network. Previously had no issues casting to Chromecast or to Samsung TV. Now can't cast to either via the satelittes but can with just the ro...
Dec 27, 2021Guru - Experienced User
Try turning off AX for 2.4hz
CTS set to 2347
SKEN57
Firmware is the very latest production version for the RBR750 4.6.5.14, tried with AX off and on, CTS set to 2347.
I have several (3) satellites, all set at optimum distance from the RBR750, over 30 feet to cover 3000 sq ft. I have 1Gbs Virgin Media cable, the provided router is as standard Hub4 and set to Cable Modem mode with latest firmware. This is only since I switched from an RBR/RBS50 setup and I had the latest firmware update. Connection straight to the router works if I turn off all satellites but signal strength not best.
- FURRYe38Dec 27, 2021Guru - Experienced User
What happens if you leave all RBS OFF accept for 1 RBS?
- SKEN57Dec 28, 2021Aspirant
No difference at all, only difference is if I turn off all satellites
- FURRYe38Dec 28, 2021Guru - Experienced User
I would make contact with NG support and let them know what your seeing with and with out the RBS enabled for Chromecast. Seems like something isn't happening with RBS enabled...Something NG should look into.
