SKEN57
Dec 27, 2021Aspirant
Unable to cast via RBS750
I have recently switched over to an RBR750/RBS750 wifi 6 network. Previously had no issues casting to Chromecast or to Samsung TV. Now can't cast to either via the satelittes but can with just the ro...
Dec 27, 2021Guru - Experienced User
What happens if you leave all RBS OFF accept for 1 RBS?
SKEN57
Dec 28, 2021Aspirant
No difference at all, only difference is if I turn off all satellites
- FURRYe38Dec 28, 2021Guru - Experienced User
I would make contact with NG support and let them know what your seeing with and with out the RBS enabled for Chromecast. Seems like something isn't happening with RBS enabled...Something NG should look into.
