jimk1963
May 15, 2024Virtuoso
Re: Unable to connect at 6 GHz to the Orbi RBRE960
Any resolution to this? I have a Dell XPS 15 9530 w/ Intel AX211 6E card and Orbi RBK963 (router + 2 sats). Orbi settings are identical to the author's settings in first post. AX211 settings ...
- May 15, 2024Solution? I’m now able get 6GHz on both iPhone and laptop. On iPhone, I selected “Forget this network” and reattached.
On laptop, I skipped Dell’s update and went straight to Intel, whose driver was much newer.
Both devices can now reach the limit of my WWAN (1Gbps).
TC_in_Montana
jimk1963
What version of Windows do you have.
If not Windows 11 you won't see 6GHz. Windows 10 and earlier does not support 6GHz.
- CrimpOnMay 15, 2024Guru - Experienced User
Dell's web site appears to indicate that Dell 'recommends' Windows 11 for this product:
https://www.dell.com/en-us/shop/dell-laptops/xps-15-laptop/spd/xps-15-9530-laptop
There are Control Panel network settings that determine which WiFi frequencies the card can use. Perhaps it would be worth a few seconds double checking that 6GHz is enabled?
- jimk1963May 15, 2024VirtuosoDidn’t find any specific settings to enable/disable 6 GHz, other than in the WLAN adapter settings.
- jimk1963May 15, 2024VirtuosoSolution? I’m now able get 6GHz on both iPhone and laptop. On iPhone, I selected “Forget this network” and reattached.
- jimk1963May 15, 2024VirtuosoWin11 Pro, familiar with that requirement.
