jimk1963
May 15, 2024Virtuoso
Re: Unable to connect at 6 GHz to the Orbi RBRE960
Any resolution to this? I have a Dell XPS 15 9530 w/ Intel AX211 6E card and Orbi RBK963 (router + 2 sats). Orbi settings are identical to the author's settings in first post. AX211 settings ...
- May 15, 2024Solution? I’m now able get 6GHz on both iPhone and laptop. On iPhone, I selected “Forget this network” and reattached.
On laptop, I skipped Dell’s update and went straight to Intel, whose driver was much newer.
Both devices can now reach the limit of my WWAN (1Gbps).
jimk1963
May 16, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
