Web-raider's avatar
Jun 27, 2025
Where is the new v.7 firmware for RBS350
I have an RBR750 with 2 RBS350, I see the lastest firmware for the RBR is 7.2.7.15. It took me some time but the last time I upgraded my router to 7.2.6.31, I was able to find the RBS350 firmware of...
  • FURRYe38's avatar
    Let us know your results after getting the RBS updated. If problems continue we can troubleshoot more then.
    Might consider a full on factory reset and setup from scratch after FW is updated.
    Web-raider wrote:
    This should work just fine thanks for that.
    My RBS350 are currently running 7.2.6.31 and prior to your post I updated my RBS750 & RBR750 to 7.2.7.15.
    I really hope this new upgrade fixes the loss of connectivity to my internet, It makes working from home unbearable when your internet keeps dropping. I have frontier fiber which is a direct 1 gig ethernet connection from the ONT straight into my orbi and then I have a 500mb backup internet connection with Spectrum which has never gone done and it has a really old netgear Docsis 3.0 router that has never gone down, go figure.
