Redlightning88
Dec 16, 2019Tutor
Where is traffic separation for the Guest network?
Set up the AX 6000 to replace a 4 unit Orbi Pro system with only minor hiccups. One of the main reasons I used the pro was the ability, VS the regular orbi at the time, to separate the three networks....
SW_
Dec 17, 2019Prodigy
I don't have this new model, but it's possible to do what you want with older model RBR50 via Guest Network. By default Guest Nework is not allowed to see local network and other clients on the same Guest network. If you put Tesla on Guest with a separate Guest SSID, it should be isolated from the rest.
Check out this: How to separate 2.4GHz/5GHz SSIDs for Guest Network
Redlightning88
Dec 17, 2019Tutor
Yes, the Orbi can do that now via firmware update long after I had to switch to the pro.
SW_ wrote:I don't have this new model, but it's possible to do what you want with older model RBR50 via Guest Network. By default Guest Nework is not allowed to see local network and other clients on the same Guest network. If you put Tesla on Guest with a separate Guest SSID, it should be isolated from the rest.
