ArunGupta
Dec 26, 2022Apprentice
WiFi 6E speed slow
I have the RBKE 960 main router connected directly to Verizon Gigabit ethernet cable. At the Verizon cable, I am getting 900/900 download/upload speed. However, connected to WiFi 6E, I barely exceed ...
Dec 27, 2022Guru - Experienced User
Because some do have routing functions built in.
Do you have the orbi set to have a separate 6ghz network? (its possible in the wifi settings)
ArunGupta
Dec 27, 2022Apprentice
The ONT is inside Verizon box which can be opened only by Verizon techs. I very much doubt it has any routing built-in. The Orbi is getting the public IP. Even then, when hardwired network speed is 900/900 even at Orbi ethernet port, the WiFi 6E seems to be a problem here.
I do not have a separate 6E network. In one of the previous discussions I had on this forum, I was asked to turn it off.
- plemansDec 28, 2022Guru - Experienced User
If you have it turned off, how are you certain its connecting to 6ghz?
Have you tried changing the 6ghz channel?
Are you using parental controls, armor, etc?
- ArunGuptaDec 28, 2022Apprentice
The phone has an indicator which shows 6E against the WiFi signal strength indicator and that is how I know.
I have tried turning on the 6E channel and results are the same.
I am not using parental controls. Netgear Armor shows it is in use but I have not configured anything to use it. Not sure if I can disable it. I do not need it.
Did you try testing different 6ghz channels on the orbi?
Or testing a different 6ghz capable device?
