bpaskin
Oct 18, 2020Aspirant
Wired connections not working with Dynamic DNS
I have a weird connection issue that only happens with wired connections. Wireless connections are fine. I have a RBR850 router and RBS850 satellite, but I am only concerned about the router. Both...
Mikey94025
Oct 20, 2020Hero
Loopback can be a problem with switches, e.g., https://community.netgear.com/t5/Orbi-AX/RBK852-Nat-loopback-bug-on-satellite/m-p/1938722/highlight/true
bpaskin
Oct 20, 2020Aspirant
Yeah, I ordered a new switch that is arriving today.
- FURRYe38Oct 20, 2020Guru - Experienced User
Which model and mfr switch did you order?
bpaskin wrote:Yeah, I ordered a new switch that is arriving today.
- bpaskinOct 20, 2020Aspirant
Netgear GS308 unmanaged switch. It has arrived, I will replace the other one later this evening.
Brian
New switch did not help.
Would anyone recommend a different switch that works with loopback witht the Orbi?
Brian
Not sure if NG GS 1 series v4 will work in that regard. I do have mine set up with a segment thats daisy changed to my RBS. A 108 and two 105s then RBS...there a quick way I can check this to maybe help find out?
