DWost
Jun 15, 2022Tutor
Working Device Not Shown In Browser Interface Or Phone App
Any updates from Netgear on this??? I'm continuing to have this same issue. I have 100+ devices and 9 satellites, nothing is showing up on the web interface at all. I'm running V4.6.8.2_2.1.9.
Jun 17, 2022Guru - Experienced User
What model are these LAN switches? PoE maybe causing problems.
What happens if you remove the switches from the mix and connect a couple devices directly to the back of the RBR? Does anything appear in the browser? Try MS Edge or Firefox to see if same thing happens there...
