christoepherr
Mar 31, 2022Tutor
Really at a loss? Self-Assigned IP with Ethernet
I'm really at a loss here and need some help. I'm not sure what happened or what I did. Will try and explain the best I can. I have CenturyLink Fiber Internet and was given a CX4000 modem/router....
Apr 01, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I have CenturyLink Fiber Internet and was given a CX4000 modem/router. The CX4000 was plugged into the patch panel in my closet. In my patch panel I have four white Ethernet cables that correspond to the floor levels in my town home. Each level has one Ethernet port. Those cables are plugged into ports 1-4 of the CX4000. Then there is one blue Ethernet cable that is plugged into the WAN port of the CX4000.
I went into the CX4000 settings to setup Transparent Bridge mode and then removed it from the equation.
I plugged in my RBR850 to the patch panel. The blue Ethernet cable is plugged into the WAN port of the RBR850 and I plugged the other four Ethernet cables into ports 1-4 so each floor can use the Ethernet jacks. I used my PPoE setting to login to get the Internet working for the router settings.
I was able to plug my laptop directly into the wall and everything worked fine. I did a reset and now I get a Self Assigned IP every time I plug my laptop to any jack on the wall. I just did a router reset and don't know why this is happening. Can anyone help? These are my VLAN settings below:
christoepherr
Apr 01, 2022Tutor
I don’t have the CenturyLink modem/router being used at all though. It’s in a box packed away. The Orbi Router is the only device plugged into the patch panel in my closet. Everything was working before. I just don’t know how a router reset would cause my Ethernet jacks in the wall to no longer provide Internet and I get a self assigned IP when I try to use them now.
