Mar 14, 2022Aspirant
Reboot daily?
Hi all i hope you can help. I bought the AS42000 in Nov, it passed Netgear’s support period. For the past 1week, I need to reboot the AS42000 daily. The red light on and no connection wit...
Mar 14, 2022Guru - Experienced User
What an AS42000?
- 99999Mar 14, 2022Aspirant
Typo
it should be AX4200 or RBR750
daily reboot
- FURRYe38Mar 14, 2022Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
99999 wrote:
Typo
daily reboot
- 99999Mar 22, 2022AspirantI finally default reset it, running for 2 days already, no reboot needed yet. I hope it is fixed. Thanks all 😜
