Mar 14, 2022Aspirant
Reboot daily?
Hi all i hope you can help. I bought the AS42000 in Nov, it passed Netgear’s support period. For the past 1week, I need to reboot the AS42000 daily. The red light on and no connection wit...
99999
Typo
it should be AX4200 or RBR750
daily reboot
Mar 14, 2022Guru - Experienced User
99999 wrote:
Typo
daily reboot
- 99999Mar 22, 2022AspirantI finally default reset it, running for 2 days already, no reboot needed yet. I hope it is fixed. Thanks all 😜
- FURRYe38Mar 22, 2022Guru - Experienced User
Glad you got it working. Please give feed back next time to questions that are presented.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
