javiersalasf
Dec 18, 2024Aspirant
Recommendations when there is a power outage
Hi! I'm looking for recommendations how to handle or what to do with orbi mesh when there is a power outage, let me explain the issue that I faced yesterday. There was no power outage but I h...
CrimpOn
Dec 18, 2024Guru - Experienced User
Yes, the recommended sequence is:
- ISP modem first
- Then router
- Then satellites
- Then user devices (This is often frustrating because user devices are spread all over the house and restarting them manually is often impractical - hard to reach, behind furniture, etc.)
Are all the major devices connected now? and the principal "issue" is where IoT devices are connected? If so, are the IoT devices working properly and the issue is that you want them connected differently?
javiersalasf
Hi!
All is connected and working now, but yeah is more related to how it was connected, basically having all the IOT devices connected to the router is weird as literally I have IOT devices next to a satellite, but it is connected to the router that is very far.
Thank you
