javiersalasf
Dec 18, 2024Aspirant
Recommendations when there is a power outage
Hi! I'm looking for recommendations how to handle or what to do with orbi mesh when there is a power outage, let me explain the issue that I faced yesterday. There was no power outage but I h...
javiersalasf
Also, is there any change that I have to do in the ISP modem? such as disable DHCP and let the orbi router be the DHCP? or any special configuration on both devices (Orbi Router and ISP modem)
Dec 18, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 UTP is recommended.
- javiersalasfDec 18, 2024Aspirant
Hi
I have a ugreen cat8 cable and the modem provided by the ISP is a Huawei HG8145V5
- FURRYe38Dec 23, 2024Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
