javiersalasf
Dec 18, 2024Aspirant
Recommendations when there is a power outage
Hi! I'm looking for recommendations how to handle or what to do with orbi mesh when there is a power outage, let me explain the issue that I faced yesterday. There was no power outage but I h...
Dec 18, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 UTP is recommended.
javiersalasf
Hi
I have a ugreen cat8 cable and the modem provided by the ISP is a Huawei HG8145V5
- FURRYe38Dec 23, 2024Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
