kinsham
Nov 06, 2021Tutor
Red LED always on in AP Mode
I use my RBR350 in AP mode. The status LED is permanently red after boot up which I presume is because there is nothing connected to the WAN port. There doesn't appear to be any way to turn this LED o...
- Nov 06, 2021
In AP mode, you should have the wan port on the RBR350 connected to your router
kinsham
Nov 06, 2021Tutor
Thanks for that. I hadn't realised that. I had thought that the WAN port was only for a modem connection. I switched it over and now the light is off and Internet is good. As a bonus i get an extra port on the RBR350.
Nov 06, 2021Guru - Experienced User
Glad to see its resolved!
