buckaroob88
May 14, 2021Initiate
Redundant internet connection possible?
I'm thinking of moving to an Orbi mesh system, but I was wondering if it is possible to configure a redundant internet connection, e.g. have cable modem as primary connection, but use cell or satelli...
May 21, 2021Guru - Experienced User
You able to try this out?
buckaroob88 wrote:I'm thinking of moving to an Orbi mesh system, but I was wondering if it is possible to configure a redundant internet connection, e.g. have cable modem as primary connection, but use cell or satellite if the primary goes down? I didn't see anything in the manual, but might it be possible to kluge it with the aggregate connection?
buckaroob88
May 21, 2021Initiate
No, I wound up keeping my Asus router (which can do this) and just used the Orbi mesh in access point mode. I was afraid to set it up that way because I thought the AP mode would allow guest wifi traffic in the LAN between the AP and router, but I found out the guest wifi prevents access to the LAN and routes traffic directly out the router which was an acceptable solution.
- FURRYe38May 21, 2021Guru - Experienced User
Kewl. Enjoy. Mark your thread as solved so others will know.
:smileywink:
