TheIntro
Mar 09, 2022Aspirant
Region change on Netgear Orbi RBK752
Hello, I am planning to purchase the Netgear Orbi RBK752 in the USA and am planning to take it to India for use there. I wanted to know from the existing owners if the region of the product can be ...
Mar 09, 2022Guru - Experienced User
There is no region setting on Orbi.
Most Orbi systems here in the USA only have 110v adapters. Though my 8 series seems to be dual voltage.
- TheIntroMar 09, 2022AspirantThank you for the reply.
So, does it mean that it can be used anywhere around the world and the region is automatically detected when setting up the device? Or is it locked to North America?
Thanks.- FURRYe38Mar 09, 2022Guru - Experienced User
Not really sure if it will auto region change. I don't see India or Bahasa in the language drop down menu for the RBRs web page so I don't know if the India region will be used. You might contact NG support to see what is officially supported.
I actually spoke to a netgear agent through chat. They told me that the region can be changed. That is the reason I wanted the existing owners to confirm if the region can be changed and India is available in the list and also to confirm that the product is not locked to North America.
Thanks.
