TheIntro
Mar 09, 2022Aspirant
Region change on Netgear Orbi RBK752
Hello, I am planning to purchase the Netgear Orbi RBK752 in the USA and am planning to take it to India for use there. I wanted to know from the existing owners if the region of the product can be ...
TheIntro
I was going through the manual and it says it can be done. These are the steps:
Select ADVANCED> Advanced> Wireless settings. There is a Region menu there. So, it would be great if anyone could check that.
Thanks.
Thanks.
Mar 09, 2022Guru - Experienced User
Ok so yes, you can change region here, however mine is grayed out so it maybe locked in here since this is used and was first setup in the USA.
I don't know if this opens up if taken to a different region or if this is only open for other regions if the unit is bought outside of the USA.
Something to ask NG about before you buy.
