Rob1988
Aug 11, 2022Aspirant
Regular Guest WiFi Drops
I just purchased RBR750 w/ 1 RBS750. Ran into the exact issue with guest WiFi. I manually updated the firmware to V4.6.8.5_2.1.9 but the issue is still ongoing with guest network only.
I have tried...
Sep 20, 2022Guru - Experienced User
How often are these disconnects with the guests devices seen?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a factory reset and setup from scratch been performed with out enabling any Armor or SPC?
