LaurieMABR
Jun 21, 2022Aspirant
Reinstalling Orbi to same network because I screwed up
I installed my RBK753 (Orbi Mesh Wifi 6 System 3 Pack) and then changed the name to my service provider router name. It really messed everything up. So...I want to re-set to factory settings and try ...
Jun 21, 2022Guru - Experienced User
Yes press the reset button in back for 15 seconds then release. I recommend walking thru the setup wizard at 192.168.1.1 with a wired PC or laptop and web browser.
LaurieMABR
Thank you. It says I am on now. We shall see.
- FURRYe38Jun 21, 2022Guru - Experienced User
