farmrt88
Jan 24, 2020Star
Release date for Add-on Orbi WiFi6 Satellite (RBS850)
 There is now a web page for the RBS 850 Add-on satelite along with a release date on Amazon... March 1, 2020     https://www.netgear.com/orbi/rbs850.aspx     https://www.amazon.com/dp/B083YRSCM9?tag=...
wififast
Apr 10, 2020Aspirant
Have only seen "Coming Soon"
farmrt88
Apr 10, 2020Star
$379.99 was the list price when it was available. From personal experience, 1 ORBI RBS850 Wifi 6 Satelite works as well as 2 RBS50 Satelites in the same environment.
- TXSoxFanApr 10, 2020Aspirant
Thanks for the info. Seems an odd price points that it would be $80 cheaper MSRP for a 3 pack than going the 2 plus an add-on, but maybe that is their intention. Either way since I got my 2 pack for $599, it still works out slightly cheaper.
I will test with just 2, but right now I am running 4 in total including an outdoor one. My fear with just the two is that I'll lose connectivity on the patio, but time will tell.
- TXSoxFanApr 11, 2020Aspirant
Update - I reached out to support and they couldn't tell me any additional info (not that I would trust anything she said after telling me to use a RBS50 instead). Because there is a limited return window, no release date and the price point would only be a net $20 difference I cancelled the 2 pack and went with the 3 pack. I am hopeful that 3 will be sufficient to cover the house and patio/backyard.
- FURRYe38Apr 11, 2020Guru - Experienced User
TXSoxFan wrote:Update - I reached out to support and they couldn't tell me any additional info (not that I would trust anything she said after telling me to use a RBS50 instead). Because there is a limited return window, no release date and the price point would only be a net $20 difference I cancelled the 2 pack and went with the 3 pack. I am hopeful that 3 will be sufficient to cover the house and patio/backyard.
