Rikerrock
Jun 01, 2023Tutor
Remote Administration: Can't seem to get it to work even though I've enabled it
Have a 850 unit with some satelites and I've enabled the remote administration (I want to be able to use my browswer to configure port forwarding and the app on my IPhone wont do that) and I've added...
Rikerrock
Jun 01, 2023Tutor
Most recent firmware is installed.
I'd like to be able to login to the gui from my work and manage the orbi router from there via web browswer. I thought that was what the remote administation page and settings are used for.
Am I wrong?
Is there a way to do this?
Thanks
Jun 01, 2023Guru - Experienced User
Would you please post a screen capture if this remote location please here in the thread for review.
- RikerrockJun 01, 2023Tutor
It's under advanced then web services management. I then chose a port other than the default 8443, but I did try that one as well.
