Rikerrock
Jun 01, 2023Tutor
Remote Administration: Can't seem to get it to work even though I've enabled it
Have a 850 unit with some satelites and I've enabled the remote administration (I want to be able to use my browswer to configure port forwarding and the app on my IPhone wont do that) and I've added...
Jun 02, 2023Guru - Experienced User
What is the FW version that is currently installed?
Rikerrock
Jun 02, 2023Tutor
V4.6.14.3 and sorry it's a rbr840
- FURRYe38Jun 02, 2023Guru - Experienced User
Ok, might explain some of it. Just be aware that remote access is no longer supported via WAN side to the web ui of the router. NG remove that in other model routers a while back due to security reasons.
I recommend using a VPN or remote access app solution like team viewer to get access to the routers web page if you need remote access to the routers web page.
Good luck.
