dbrb2
Dec 26, 2024Apprentice
Remote reboot RBR750
I have an RBR750 and an RBS750 At some point this evening, the RBR stopped acting as a wireless AP It still has an IP, and can be pinged - but the web UI returns a code 500 error I'm remo...
Dec 27, 2024Guru - Experienced User
what is giving you the error?
Trying to figure out exactly what you're trying to do and attempting to do with the remote access
dbrb2
Dec 27, 2024Apprentice
Hi
The error comes when attempting to access the web interface
It started on the 26th whilst I was away, and has persisted over a power cycle.
The symptoms are that no wireless devices can use it as an AP
I can't work out what could have triggered it, though I should have local access later this coming weekend. However, since a power cycle hasn't fixed it it feels like a factory reset may be needed....
