td32016
Aug 30, 2023Follower
remove router from account/app
I have an Orbi system that works just fine. I offered to set up an Orbi system for a friend. Created them an account, life is good. Except, I was logged into that account on the mobile app and someho...
td3201
Aug 31, 2023Aspirant
I'm sorry for leaving out this detail but I had already removed the product(s) from their profile under My Registered Products so that all looks correct.
Aug 31, 2023Guru - Experienced User
I think you'd need to factory reset your system now then setup from scratching while at your location and then you should be able to register it with your account. Registration only happens when setting up out of the box or first time walking thru the setup wizard. So a factory reset would be needed on the RBR.
- td3201Aug 31, 2023Aspirant
Let me be more clear because I haven't been thus far.
Current state:
System 1
- Associated with Account 2 in the mobile app
- NOT registered on MyProducts to Account 2
System 2
- Waiting to be configured
Desired state:
System 1
- Associated with Account 1
- No factory reset, it's working
- Visible in App when I login with Account 1
System 2
- Visible in App when I login with Account 2
- Can set up as a fresh new system
