Rob6805
Nov 20, 2022Tutor
Reolink E1 zoom won't connect to Orbi satellite.
Hello all, I am at my wits end. I purchased a Orbi mesh wifi system (simultaneous 2.4 and 5ghz). It has a main router and two satellites. The system works perfectly except for getting cameras ...
TLM978
Dec 07, 2022Tutor
I have tried multiple times to connect my Reolink E1 to Orbi RBK863S and it fails every time. It will connect to my RAX75 router no issues.
- Rob6805Dec 07, 2022Tutor
My Reolink E1 did start connecting to the RBS350 satellite. I believe what I had to do was connect it to the main router (RBR750) and then sync the satellite to the router. After confirming the satellite is working (I used a wifi analyzer phone app) I rebooted the Reolink camera and it connected to the satellite. If I had the satellite synced to the router FIRST and then tried to connect the Reolink camera it would only use the very weak router signal and not the satellite. Hope this makes sense.
