ronfriedman
Aug 22, 2020Aspirant
Replace Model RBK 50 AC 3000 with Orbi WiFi 6??
I have had an Orbi RBK 50 system with one satellite installed in a 3000 sq ft home for approximately 3 years. Am generally happy with it. It is WiFi 5. MY ISP is Comcast and I recently upgraded my...
Aug 22, 2020Guru - Experienced User
If your current Orbi system is working well and your getting to spec speeds, I would keep what you have. Unless you can take full advantage of wifi 6 and AX mode, then might hold off. AX is recommended for 1Gb ISP speeds.
You could try the Orbi AX and see how it works for you. If not, then you could return it.
- ronfriedmanAug 22, 2020Aspirant
Thank you!
- FURRYe38Aug 22, 2020Guru - Experienced User
:smileywink:
