gumpgump
Dec 29, 2020Guide
Replace Netgear Orbi WIFI 6 Router with Netgear Orbi WIFI 6 Cablemodem Router?
I recently had a cablemodem snafu. I have a new Netgear Orbi WIFI 6 Router and Satellite. I'd consider replacing the Router with the equivalent Netgear Orbi WIFI 6 Cablemodem/router -- but i...
gumpgump
Dec 29, 2020Guide
I should have mentioned, I have a Netgear CM1000 now. It does not have a router or VPN on it, I know I could buy a different model to get those features.
Dec 29, 2020Guru - Experienced User
Cm1000 is a good modem. Most modems won't have VPN unless you get a gateway modem. CM series are modems only. C series or CBR series are modems with built in routers and wifi.
Your Orbi should do some of this...or you can use pass thru VPNs on your devices...
- gumpgumpDec 29, 2020Guide
I have used OpenVPN with my other Orbis just fine. My concern is if for some unforeseen reason the Orbi went offline, then I wouldn't be able to access. If I have VPN running from the actual cablemodem, that might be an option.
- FURRYe38Dec 29, 2020Guru - Experienced User
Would be same kind of issue there too, if it goes down there then your just moving the problem from one place to another.
