lagunatic
Oct 25, 2024Guide
Replace old RBR50 with RBR850/RBS850 (RBK852) - initial setup issues
I have an old existing RBR50 with an outlet-plugin satellite. Replacing with a brand new RBK852. Already been using the Orbi app on iOS but I uninstalled and reinstalled the app prior to attempting t...
- Oct 26, 2024
I don't have any issues saving config files using MS Edge, just the nag popup after selecting the backup button, that in the MS Edge download section I get the warning about downloading the file. The is 3 dots on the warning about the file. I select this then select KEEP and the file gets downloaded to the download folder is all.
Yes.
Oct 25, 2024Guru - Experienced User
What brand and model ISP modem is the RBR connected too?
You might review this and reset and setup from scratch using the PDF process. I use it always when bringing on a new system:
lagunatic
Oct 25, 2024Guide
The RBR850 is connected to an 'ARRIS SURFboard SB8200' cable modem (it's been very solid, never had an issue with it).
ISP is Spectrum. Speedtest app on my main PC (Win11 24H2, i9-9900KS CPU, 64GB RAM) gives me roughly 675Mbps down, 23Mbps up, PING 7ms.
I purchased the RBK852 direct from Netgear three days ago so I have 1yr of tech support and will likely give them a call in addition to reaching out here.
I've downloaded the PDF and will walk through it soon.
Thanks for such a quick reply!
