lagunatic
Oct 25, 2024Guide
Replace old RBR50 with RBR850/RBS850 (RBK852) - initial setup issues
I have an old existing RBR50 with an outlet-plugin satellite. Replacing with a brand new RBK852. Already been using the Orbi app on iOS but I uninstalled and reinstalled the app prior to attempting t...
- Oct 26, 2024
I don't have any issues saving config files using MS Edge, just the nag popup after selecting the backup button, that in the MS Edge download section I get the warning about downloading the file. The is 3 dots on the warning about the file. I select this then select KEEP and the file gets downloaded to the download folder is all.
Yes.
lagunatic
Oct 26, 2024Guide
Well, the one item I haven't completed is the .cfg backup. Struggling to get Edge to allow the download. Haven't figure out the workaround to that yet for the latest version of Edge v130. I disabled SmartScreen and it still grumped the file was unsafe. I also have Norton 360 A/V running but it seems Edge is the issue, not Norton. Suggestion?
Sorry - first posting here. When you say mark as solved, I assume you mean I should click on 'Accept As Solution'?, correct?
Oct 26, 2024Guru - Experienced User
Yes.
- FURRYe38Oct 26, 2024Guru - Experienced User
Well you can always save off with a different browser as well. Don't have to use MS Edge.
Enjoy.
