lagunatic
Oct 25, 2024Aspirant
Replace old RBR50 with RBR850/RBS850 (RBK852) - initial setup issues
I have an old existing RBR50 with an outlet-plugin satellite. Replacing with a brand new RBK852. Already been using the Orbi app on iOS but I uninstalled and reinstalled the app prior to attempting t...
- Oct 26, 2024
I don't have any issues saving config files using MS Edge, just the nag popup after selecting the backup button, that in the MS Edge download section I get the warning about downloading the file. The is 3 dots on the warning about the file. I select this then select KEEP and the file gets downloaded to the download folder is all.
Yes.
Oct 26, 2024Guru - Experienced User
Yes.
lagunatic
Oct 26, 2024Aspirant
I had tried the Keep option prior multiple times and it didn't work, but just did it again and all is good. Odd.
Thanks FURRYe38 ... you've been extemely helpful.
- FURRYe38Oct 26, 2024Guru - Experienced User
Well you can always save off with a different browser as well. Don't have to use MS Edge.
Enjoy.
