RussQuick
May 17, 2024Tutor
Replaced BT WholeHub with Orbi 852 - Copied SSID and password but nothing reconnects
Hi all, Hope someone can help, its driving me Bonkers after spending £400 on this gear. So I managed to overcome the BT hurdle of connecting the Orbi Router straight to the FTTP box on the wa...
- May 17, 2024
Sorry everyone - I may have wasted your time. Despite starring at the SSID and password for 4hrs straight turned out that going to work and coming home got my mind onto others things and I have come Back to see that within the SSID I missed 1 Capital letter. All Wifi clients have now rejoined.
Thanks for your support though
michaelkenward
May 17, 2024Guru - Experienced User
RussQuick wrote:
So I managed to overcome the BT hurdle of connecting the Orbi Router straight to the FTTP box on the wall from BT and connected details using PPPoE, all fine interent connection sorted.
What is this WholeHub? Is that the Wholehome Hub? The Smart Hub?
What connects that to the Internet?
What is the "FTTP box on the wall"?
However, upon setup of the ORbi I used the card from the back of my old Wholehome hub mesh netwrok to copy the SSID and password which is what all the 30-40 devices in my home were connected to, through the old BT HOMEhub and satellites around the house. Done on the assumption this would beeasier and they would all reconnect.
Are you saying that you went into a web browser and the graphical user interface (GUI) for the Orbi and gave it the same SSID and password that you used with the BT kit?
However not one of them has re-established connection. I have checked the details for the Orbi SSID and password to make sure it matches the old details and its spot on yet nothing reconnects.
If I go to some of the items like TV's and Apple TV's the netwrok shows up with the same name when looking at available networks, ill click it but then it askes for the password. It seems something is telling the devices its not the same netwrok, despite it having the same SSID and password.
So, it is the wifi clients that cause the problem while you assume that it is the Orbi router. Sadly, wifi clients have wills of their own. They may not rely solely on the SSID and password to check the wifi. Some will want to verify the MAC address.
Have you tried setting up one of these wifi clients from scratch to see if it will connect to the Orbi network?
I have checked IP range and thats goes from .2 to .254.
And the bit at the front is?
I fear that your attempts to circumvent the setup process may be getting in the way. Have you tried this issue in the BT Community? I see several similar discussions there.
