RussQuick
May 17, 2024Tutor
Replaced BT WholeHub with Orbi 852 - Copied SSID and password but nothing reconnects
Hi all, Hope someone can help, its driving me Bonkers after spending £400 on this gear. So I managed to overcome the BT hurdle of connecting the Orbi Router straight to the FTTP box on the wa...
- May 17, 2024
Sorry everyone - I may have wasted your time. Despite starring at the SSID and password for 4hrs straight turned out that going to work and coming home got my mind onto others things and I have come Back to see that within the SSID I missed 1 Capital letter. All Wifi clients have now rejoined.
Thanks for your support though
RussQuick
May 17, 2024Tutor
Thanks for your reply
What is this WholeHub? Is that the Wholehome Hub? The Smart Hub? Smart HUb used to connect to a mesh netwrok which boost the smarthub around the home and BT call this the Wholehome I think
What connects that to the Internet? The box on wall was wired (etherent) into Smarthub and then wholehome satellites create the Mesh network. But the new setup is doing away with all that BT stuff and I am just plugging the orbi in as a router and then an orbi satellite on other side of the house
What is the "FTTP box on the wall"? Apologies I am calling things names that I believe they are called but I am no expert so not 100% things like "FTTP box" on the wall is the right name. EssentiallThe line comes straight to the door and then there is a box on the wall that came with the house a new build and then a etherent cable comes from that to the Router.
Are you saying that you went into a web browser and the graphical user interface (GUI) for the Orbi and gave it the same SSID and password that you used with the BT kit? Yes but using the Orbi App during Setup
So, it is the wifi clients that cause the problem while you assume that it is the Orbi router. Sadly, wifi clients have wills of their own. They may not rely solely on the SSID and password to check the wifi. Some will want to verify the MAC address.
Have you tried setting up one of these wifi clients from scratch to see if it will connect to the Orbi network? I have connected an Ipad , that wasnt used with the setup and it connected fine, when I enter the password and connect it like that. Seems like its things its a diifferent SSID rather than the same.
And the bit at the front is? Sorry could you explain what this means
I fear that your attempts to circumvent the setup process may be getting in the way. Have you tried this issue in the BT Community? I see several similar discussions there.No I have tried this on BT as I assummed it was an Orbi set up issue
Thanks for taking the time to respond.
RussQuick
May 17, 2024Tutor
- FURRYe38May 17, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
