lbelardinelli
Dec 19, 2020Aspirant
replacing my old router with new Orbi RBK853
I am looking for recommendations on replacing my old netgear router and 24 port netgear switch with new Orbi RBK853 but using the same switch. My system is complicated (to me). I have 15 devices (com...
Dec 19, 2020Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
IF your going to ethernet connect RBS, here is the configuration thats needed:
You can use same LAN IP address scheme if you like. Also use same wifi SSID name and PW is recommended.
