lbelardinelli
Dec 19, 2020Aspirant
replacing my old router with new Orbi RBK853
I am looking for recommendations on replacing my old netgear router and 24 port netgear switch with new Orbi RBK853 but using the same switch. My system is complicated (to me). I have 15 devices (com...
ekhalil
Dec 22, 2020Master
lbelardinelli wrote:......
1) Should I hard wire the 3 Orbi units together? (I can do that because the entire home/office is wired) or do I just let them go wireless?
If you have the possibility to use wired backhaul then I would go for that. Wired is always more reliable than wireless, I think! :)
2) SHould I use my old router IP address of 172.16..... or use a different one. A
Up to you, you can still use the old IP range if you would like to keep the same old records.
3) Will my wireless devices find the new router DHCP server and then I would just start fixing the other devices?
If you use the same SSID and password then the old devices will automatically find the new router and use the DHCP for IP access.
Good luck!
- lbelardinelliDec 22, 2020Aspirant
I havent impliminated the change yet. The Orbi JUST arrived and now I decided that I would also replace my old switch. I have a 8 year old fs726TP and I decided to get a new GS324TP. Once it arrives, probably next week, I will start my changeover. I dont look forward to it with around 18 fixed IP devices and 55 or so Smart home devices (They run my whole life - Hot water tank temp, house temp, pool temp jacuzzi temp, My solar panels, 6 computers, 3 TVs and I can go on).
- FURRYe38Dec 22, 2020Guru - Experienced User
What is your currennt DHCP configuration and pool size that you use?
Be sure that you disable any and all IGMP protocols on the new switch if you connect the RBS via ethernet to this switch. I don't see any green ethernet features on this new switch so you should ok there.
- lbelardinelliDec 23, 2020Aspirant
My IP conig on my present system router is:
Router: 172.16.0.1
Fixed device asignments: are 0.2 thru 0.49
Dhcp range 0.50 thru 0.200
(NOTE: MY HOUSE IS WIRED FOR 20 IP ports)
Hard wired devices with Fixed IPs are:
1 switch (now a Netgear FS726TP but will be a Netgear GS324TP)
5 computers
2 TVs
1 Stereo AMP
1 VOIP system
2 Printers
Wifi Devices with fixed IP
1 Solar controller
1 HVAC controller
1 Pool/spa controller
1 weather station
1 Awning controller
1 Garage door controller
The rest of the devices are DHCP assigned WiFi devices
like 15 wireless speakers, security system, light controller etc
