CarlJohnDensley
Aug 05, 2022Aspirant
reset password I do not receive security questions
All is good I can log into my Wi-Fi to use it however if I want to login to the admin I cannot so I follow the directions and enter the serial number then click next but I'm not asked for security qu...
Aug 05, 2022Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Then using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
CarlJohnDensley
Aug 14, 2022Aspirant
Hello
thank you for your message. I assume I do the same with a Mac?
- iyangAug 18, 2022NETGEAR Expert
Hi CarlJohnDensley ,
I have some questions want to check with you.
Will not show security questions after you finish typing the serial number, is it right ?
What is the next screen after you finish typing the serial number ? can you share the screenshot ?
What Firmware version do you use ?
What's browser do you use ?Thanks.
