HarryGosman
Dec 19, 2023Follower
Reset RBS350
The satellites (RBS350) regularly malfunction (purple/blue lighting). I can only solve this by disconnecting the satellites from power. is there a setting to activate so that the satellite automatica...
Dec 19, 2023Guru - Experienced User
What Firmware version is currently loaded on the RBR and RBS?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
What channel configurations are currently set on the router?
RBS should not be reset or need any frequent rebooting. If this is happening then there is a problem that needs to be figured out.
