MixMaster
Feb 17, 2021Apprentice
Restart RBS850?
All, I'm a few days into setting up the RBK853 (Router and two Satellites) and have a question or two. 1) I see through the iPhone app or via a browser how I can restart the router but is the...
Federico2003
Feb 17, 2021Guide
Yes, right.
Unfortunately there is no way to restart satellites from the web interface or the Orbi app.
As you say, it is in fact necessary to act directly on the on / off button or on the power socket.
Bye!
Feb 17, 2021Guru - Experienced User
These come in handly though. :smileyvery-happy:
- FURRYe38Feb 17, 2021Guru - Experienced User
Or these could work too:
https://us.dlink.com/en/products/dsp-w118-mydlink-mini-wi-fi-smart-plug
- MixMasterFeb 17, 2021Apprentice
Got it. I have several TP-Link Smart Plugs that are similar to using the Dlink - I'll give that a shot. Can you clarify further the Sync buttons? From what I've read they "push" changes and what I'm NOT clear on is if its always initiated from the router. I believe I read that after pressing the sync on the router you have two minutes to press sync on the satellites?
Like I said earlier, this is all a new setup for me and I appreciate eveeryone's input.
- FURRYe38Feb 18, 2021Guru - Experienced User
To sync press the sync button on the RBS first then on the RBR.
