riko
Jul 07, 2021Aspirant
RGR850 shows empty device and satellite list...
Hi, i have a RBK853 system installed in my home running in AP mode...behind a web-router from my ISP(3 webgate). On the RBR there is also a lan cable connecting my wired computers. Firmwareversion o...
- Jul 08, 2021
Ok.. so i have now connected my network as it was before i had my ORBI RBK853 system...
The ISP modem(placed on 2nd floor) is connected to the cable which goes to the wired network (switch). ISP modems WLAN and DHCP is off.
DHCP is running in the wired network on a mac because of IP reservations for some special WLAN devices...i cant do this in the IPS modem.
The RBR is now connected to a switch in the wired network on 1st floor...same place where my old AP was connected...
All is now working as ist should... and i am now free to place my RBR where it best fits...
Tomorrow i will position and sync my 2 satellits ... one on the 2nd floor and one on the ground floor...
Hopefully it works this way in the end...
Jul 07, 2021Guru - Experienced User
What browser are you using? Try MS Edge, FireFox or Opera?
riko
I am using safari ... will test it with other browser in a few minutes... but in the beginning of setup i have seen the satellit and devicelist...
- FURRYe38Jul 07, 2021Guru - Experienced User
Let us know what the other browsers do...
Possible reset maybe needed if they show same thing...
- rikoJul 07, 2021Aspirant
have now downloaded and installed the firefox ... same thing shown... empty list.
I have allready restarted all 3 devices before... or do you mean now again ?
Maybe i have seen something in the firefox network inspector... there is an error in the answer... see picture...
But why is this?
