PanchoB
Aug 05, 2021Follower
Ring devices not connecting to closest satellite
I have an Orbi mesh RBK753S. I have installed 2 Ring outdoor stick up cams, and one ring floodlight/cam. They are all hardwired/plugged in. At first they connected to the closest satellite, and worked...
michaelkenward
Aug 06, 2021Guru - Experienced User
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
